Varying thin filament activation in the framework of the Huxley'57 model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Biomedical Engineering Année : 2022
Muscle contraction is triggered by the activation of the actin sites of the thin filament by calcium ions. It results that the thin filament activation level varies over time. Moreover, this activation process is also used as a regulation mechanism of the developed force. Our objective is to build a model of varying actin site activation level within the classical Huxley'57 two-state framework. This new model is obtained as an enhancement of a previously proposed formulation of the varying thick filament activation within the same framework [1]. We assume that the state of an actin site depends on whether it is activated and whether it forms a cross-bridge with the associated myosin head, which results in four possible states. The transitions between the actin site states are controlled by the global actin sites activation level and the dynamics of these transitions is coupled with the attachment-detachment process. A preliminary calibration of the model with experimental twitch contraction data obtained at varying sarcomere lengths is performed.
main.pdf (1.01 Mo) Télécharger le fichier
hal-03788978 , version 1 (27-09-2022)
hal-03788978 , version 2 (24-10-2022)
Paternité
François Kimmig, Matthieu Caruel, Dominique Chapelle. Varying thin filament activation in the framework of the Huxley'57 model. International Journal for Numerical Methods in Biomedical Engineering, 2022, ⟨10.1002/cnm.3655⟩. ⟨hal-03788978v2⟩
101 Consultations
90 Téléchargements
