Experimental study of the effect of the long chimney of a closed tonehole on the sound of a bassoon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
closed_long_chimney_v3.pdf (3.03 Mo) Télécharger le fichier
hal-03789436 , version 1 (27-09-2022)
hal-03789436 , version 2 (12-12-2022)
hal-03789436 , version 3 (17-02-2023)
  • HAL Id : hal-03789436 , version 2
Augustin Ernoult, Timo Grothe. Experimental study of the effect of the long chimney of a closed tonehole on the sound of a bassoon. 2022. ⟨hal-03789436v2⟩
49 Consultations
81 Téléchargements
