Hidden Issuer Anonymous Credential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings on Privacy Enhancing Technologies Année : 2022
Identity Management Systems (IMS) allow users to prove characteristics about themselves to multiple service providers. IMS evolved from impractical, site-by-site authentication, to versatile, privacyenhancing Self Sovereign Identity (SSI) Frameworks. SSI frameworks often use Anonymous Credential schemes to provide user privacy, and more precisely unlinkability between uses of these credentials. However, these schemes imply the disclosure of the identity of the Issuer of a given credential to any service provider. This can lead to information leaks. We deal with this problem by introducing a new Anonymous Credential scheme that allows a user to hide the Issuer of a credential, while being able to convince the service providers that they can trust the credential, in the absence of a trusted setup. We prove this new scheme secure under the Computational Diffie Hellman assumption, and Decisional Diffie Hellman assumption, in the Random Oracle Model. We show that this scheme is efficient enough to be used with laptops, and to be integrated into SSI frameworks or any other IMS.
HIAC.pdf (912.33 Ko) Télécharger le fichier
hal-03789485 , version 1 (27-09-2022)
Daniel Bosk, Davide Frey, Mathieu Gestin, Guillaume Piolle. Hidden Issuer Anonymous Credential. Proceedings on Privacy Enhancing Technologies, 2022, 2022, pp.571 - 607. ⟨10.56553/popets-2022-0123⟩. ⟨hal-03789485⟩
191 Consultations
175 Téléchargements
