Self-supervised language learning from raw audio: Lessons from the Zero Resource Speech Challenge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Journal of Selected Topics in Signal Processing Année : 2022
Recent progress in self-supervised or unsupervised machine learning has opened the possibility of building a full speech processing system from raw audio without using any textual representations or expert labels such as phonemes, dictionaries or parse trees. The contribution of the Zero Resource Speech Challenge series since 2015 has been to break down this long-term objective into four well-defined tasks-Acoustic Unit Discovery, Spoken Term Discovery, Discrete Resynthesis, and Spoken Language Modeling-and introduce associated metrics and benchmarks enabling model comparison and cumulative progress. We present an overview of the six editions of this challenge series since 2015, discuss the lessons learned, and outline the areas which need more work or give puzzling results.
JSTSP3206084 (1).pdf (10.34 Mo) Télécharger le fichier
hal-03789716 , version 1 (27-09-2022)
Ewan Dunbar, Nicolas Hamilakis, Emmanuel Dupoux. Self-supervised language learning from raw audio: Lessons from the Zero Resource Speech Challenge. IEEE Journal of Selected Topics in Signal Processing, In press, ⟨10.1109/jstsp.2022.3206084⟩. ⟨hal-03789716⟩
47 Consultations
94 Téléchargements
