Exponential stability of periodic difference delay systems and 1-D hyperbolic PDEs of conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper applies a recent characterization, due to the authors, of exponential stability for linear periodic difference delay systems to the stability of one-dimensional hyperbolic systems of PDE, and elaborates on the case where the delays are rationally independent.
TDS2022_Generalization_Hale.pdf (230.01 Ko) Télécharger le fichier
hal-03792038 , version 1 (29-09-2022)
Laurent Baratchart, Sébastien Fueyo, Jean-Baptiste Pomet. Exponential stability of periodic difference delay systems and 1-D hyperbolic PDEs of conservation laws. TDS 2022 - 17th IFAC Workshop on Time Delay Systems, Sep 2022, Montréal, Canada. pp.228-233, ⟨10.1016/j.ifacol.2022.11.362⟩. ⟨hal-03792038⟩
64 Consultations
84 Téléchargements
