Displacement smoothness of entropic optimal transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
The function that maps a family of probability measures to the solution of the dual entropic optimal transport problem is known as the Schrödinger map. We prove that when the cost function is $C^{k+1}$ with k in N* then this map is Lipschitz continuous from the $L^2$-Wasserstein space to the space of $C^k$ functions. Our result holds on compact domains and covers the multi-marginal case. As applications, we prove displacement smoothness of the entropic optimal transport cost and the well-posedness of certain Wasserstein gradient flows involving this functional, including the Sinkhorn divergence and a multi-species system.
stability-potentialsCOCV-final.pdf (334.25 Ko) Télécharger le fichier
hal-03793562 , version 1 (01-10-2022)
hal-03793562 , version 2 (01-03-2024)
  • HAL Id : hal-03793562 , version 2
Guillaume Carlier, Lénaïc Chizat, Maxime Laborde. Displacement smoothness of entropic optimal transport. 2024. ⟨hal-03793562v2⟩
119 Consultations
205 Téléchargements
