Response Time Stochastic Analysis for Fixed-Priority Stable Real-Time Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2022
In this paper, we prove that a mean system utilization smaller than one is a necessary condition for the feasibility of real-time systems. Such systems are defined as stable. Stable systems have two distinct states: a transient state, followed by a steady-state where the same distribution of response times is repeated infinitely for each task. We prove that the Liu and Layland theorem holds for stable probabilistic real-time systems with implicit deadlines, we provide an analytical approximation of response times for each of those two states and a bound of the instant when a real-time system becomes steady.
TC__special_issue___hal_inria_-2.pdf (1.75 Mo) Télécharger le fichier
hal-03797980 , version 1 (06-10-2022)
hal-03797980 , version 2 (07-10-2022)
Kevin Zagalo, Yasmina Abdeddaim, Avner Bar-Hen, Liliana Cucu-Grosjean. Response Time Stochastic Analysis for Fixed-Priority Stable Real-Time Systems. IEEE Transactions on Computers, 2022, pp.1-12. ⟨10.1109/TC.2022.3211421⟩. ⟨hal-03797980v1⟩
234 Consultations
142 Téléchargements
