Impact of lesion damages along the whole motor pathways on disability in multiple sclerosis
Introduction: The anatomical substrate of motor disability in MS patients is not fully understood. Studying
the distribution of corticospinal tracts (CST) lesions per side, from the brain to the end of the thoracic spinal cord (SC) could
provide a better association with patient motor deficits evaluated per limb.
Objectives: i) To describe lesion preferential location along the CST; ii) To investigate the association between CST lesions
and motor functional consequences, as measured using the EDSS, and the ASIA motor scores and electrophysiology (Central
motor conduction time (CMCT)) per limb.
Methods: 21 relapsing remitting MS (median EDSS=2.5) and 9 progressive MS patients (median EDSS=5.2) with clinical
pyramidal symptoms were scanned on a 3T Siemens MRI scanner. White matter lesions were segmented on 3D FLAIR for the
brain, on T2* for cervical SC and T2 for thoracic SC. For each patient, registration to an atlas was computed using Anima and
SCT toolboxes. Lesion volume fraction along the CST (defined as "lesion volume along the CST"/"overall CST volume") was
calculated separately for the both sides on 3 regions: brain including brainstem, C1 to C7 (C1C7) and T1 to T10 (T1T10).
Finally, the relationships between lesion volume fraction and the associated lateralized disability scores were assessed using
multiple linear models, adjusting for age and disease duration.
Results: In MS patients, lesion volume fraction was higher in the C1C7 portion compared to the brain and T1T10 portion (all
p’s<.001; mean=2%, 10% and 2%, for brain, C1C7 and T1T10, resp). No evidence of correlation was found between
lateralized lesion volume fraction in each portion of the CST and EDSS score or ASIA score per limb, except for a mild
correlation between EDSS and lesion volume fraction on the right CST (standardized beta=.39, p=.041). We observed strong
positive associations between lesion volume fraction in C1C7 and CMCT for superior and inferior limbs on the right side and
for superior limbs on the left side (all std-beta>.6; all p’s<.005). Finally, we observed a mild positive association between
lesion volume fraction in T1T10 and CMCT for inferior limbs on the left side (std-beta=.53; p=.02).
Conclusions: CST damage is not homogeneous along the tract and predominates in the cervical portion. It has clear
consequences on motor conduction velocities measured using electrophysiology. Future work will include an assessment of
lesion severity to better explain lesion consequences on motor disability.
