Lamb modes and Born approximation for small shape defects inversion in elastic plates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The aim of this work is to present theoretical tools to study wave propagation in elastic waveguides and perform multi-frequency scattering inversion to reconstruct small shape defects in a 2D and 3D elastic plate. Given surface multi-frequency wavefield measurements, we use a Born approximation to reconstruct localized defect in the geometry of the plate. To justify this approximation, we introduce a rigorous framework to study the propagation of elastic wavefield generated by arbitrary sources. By studying the decreasing rate of the series of inhomogeneous Lamb mode, we prove the well-posedness of the PDE that model elastic wave propagation in 2D and 3D planar waveguides. We also characterize the critical frequencies for which the Lamb decomposition is not valid. Using these results, we generalize the shape reconstruction method already developed for acoustic waveguide to 2D elastic waveguides and provide a stable reconstruction method based on a mode-by-mode spacial Fourier inversion given by the scattered field.
lamb_mode_inversion.pdf (2.48 Mo) Télécharger le fichier
hal-03798261 , version 1 (05-10-2022)
hal-03798261 , version 2 (03-05-2023)
  • HAL Id : hal-03798261 , version 1
Eric Bonnetier, Angèle Niclas, L. Seppecher. Lamb modes and Born approximation for small shape defects inversion in elastic plates. 2022. ⟨hal-03798261v1⟩
86 Consultations
62 Téléchargements
