RNN-LSTM neural network for predicting fMRI neurofeedback scores from EEG signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
Caroline Pinte
  • Fonction : Auteur
  • PersonId : 1170974
Claire Cury
Pierre Maurel
In the context of neurofeedback (NF), simultaneous acquisitions with electroencephalography (EEG) and functional magnetic resonance imaging (fMRI) provide more effective NF training due to their complementarity [1]. However, the use of MRI is expensive and draining for the subject. Therefore, we would like to reduce its use. Following the work of Cury et al. [2], we propose a method based on a recurrent neural network (RNN) that consists in learning a model from simultaneous EEG-fMRI acquisitions to predict NF-fMRI scores with EEG signals alone.
Pinte_Abstract-Poster_rtFIN2022.pdf (146.3 Ko) Télécharger le fichier
Pinte_Poster_rtFIN2022.pdf (856.05 Ko) Télécharger le fichier
hal-03798824 , version 1 (05-10-2022)
Paternité
  • HAL Id : hal-03798824 , version 1
Caroline Pinte, Claire Cury, Pierre Maurel. RNN-LSTM neural network for predicting fMRI neurofeedback scores from EEG signals. rtFIN 2022 - Real-time Functional Imaging and Neurofeedback, Oct 2022, New Haven, United States. ⟨hal-03798824⟩
173 Consultations
111 Téléchargements
