Correspondence Theory for Atomic Logics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
We develop the correspondence theory for the framework of atomic and molecular logics on the basis of the work of Goranko & Vakarelov. First, we show that atomic logics and modal polyadic logics can be embedded into each other. Using this embedding, we reformulate the notion of inductive formulas introduced by Goranko & Vakarelov into our framework. This allows us to prove correspondence theorems for atomic logics by adapting their results.
AtomicMolecularLogicsCorrespondenceTheoryPart2.pdf (584.04 Ko) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-03800044 , version 1 (06-10-2022)
  • HAL Id : hal-03800044 , version 1
Guillaume Aucher. Correspondence Theory for Atomic Logics. [Research Report] Université de Rennes 1. 2022. ⟨hal-03800044⟩
92 Consultations
51 Téléchargements
