A Formalisation of a Fast Fourier Transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This notes explains how a standard algorithm that constructs the discrete Fourier transform has been formalised and proved correct in the Coq proof assistant using the SSReflect extension.
Note.pdf (111.71 Ko) Télécharger le fichier
hal-03807965 , version 1 (10-10-2022)
hal-03807965 , version 2 (11-10-2022)
hal-03807965 , version 3 (12-10-2022)
hal-03807965 , version 4 (13-10-2022)
Laurent Théry. A Formalisation of a Fast Fourier Transform. 2022. ⟨hal-03807965v1⟩
38 Consultations
40 Téléchargements
