I/O performance of multiscale finite element simulations on HPC environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present MSLIO, a code to mimic the I/O behavior of multiscale simulations. Such an I/O kernel is useful for HPC research, as it can be executed more easily and more efficiently than the full simulations when researchers are interested in the I/O load only. We validate MSLIO by comparing it to the I/O performance of an actual simulation, and we then use it to test some possible improvements to the output routine of the MHM (Multiscale Hybrid Mixed) library.
wamca2022_extended.pdf (341.1 Ko) Télécharger le fichier
hal-03808833 , version 1 (10-10-2022)
  • HAL Id : hal-03808833 , version 1
Francieli Boito, Antonio Tadeu A. Gomes, Louis Peyrondet, Luan Teylo. I/O performance of multiscale finite element simulations on HPC environments. WAMCA 2022 - 13th Workshop on Applications for Multi-Core Architectures, Nov 2022, Bordeaux, France. ⟨hal-03808833⟩
163 Consultations
147 Téléchargements
