Optimal control of bistable travelling waves: looking for the spatial distribution of a killing action to block a pest invasion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Some pests and vectors of many vector-borne diseases (like mosquitoes for malaria and dengue) are known to invade any homogeneous and favorable territory, following a traveling wave type dynamic. The density of individuals in the field is commonly modeled as the solution of a bistable reaction-diffusion equation on an unbounded domain. In this work, we are interested in finding an optimal strategy to block such a solution by means of a population elimination action in a prescribed subdomain (modeling, for instance the effect of a mechanical action or an insecticide applied in a certain region to reduce the number of individuals in the population). We propose a complete description of the solutions of this problem, based on the precise analysis of the optimality conditions and on arguments for comparison between the possible strategies.
insecticide_ALNP.pdf (869.45 Ko) Télécharger le fichier
hal-03811940 , version 1 (12-10-2022)
  • HAL Id : hal-03811940 , version 1
Luis Almeida, Alexis Léculier, Grégoire Nadin, Yannick Privat. Optimal control of bistable travelling waves: looking for the spatial distribution of a killing action to block a pest invasion. 2022. ⟨hal-03811940⟩
186 Consultations
77 Téléchargements
