Investigating the Performances of Control Parameterizations for Nonlinear Model Predictive Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Solving Direct Shooting Model Predictive Control (MPC) optimization problems online can be computationally expensive if a large horizon is used while also maintaining a dense time sampling. In these cases, it is accepted that tradeoffs between computational load and performances should be sought in order to meet real-time feasibility requirements. However, making the problem more tractable for the hardware should not necessarily imply a decrease in performances. One technique that has been proposed in the literature makes use of control input parameterizations to decrease the numerical complexity of nonlinear MPC problems without necessarily affecting the performances significantly. In this paper, we review the use of parameterizations and propose a simple Sequential Quadratic Programming algorithm for nonlinear MPC. We then benchmark the performances of the solver in simulation, showing that parameterizations allow to attain good performances with (significantly) lower computation times than state-of-the-art solvers.
ICARCV_MPC22.pdf (1.85 Mo) Télécharger le fichier
hal-03812458 , version 1 (12-10-2022)
  • HAL Id : hal-03812458 , version 1
Franco Fusco, Guillaume Allibert, Olivier Kermorgant, Philippe Martinet. Investigating the Performances of Control Parameterizations for Nonlinear Model Predictive Control. 17th International Conference on Control, Automation, Robotics and Vision, Dec 2022, Singapore, Singapore. ⟨hal-03812458⟩
99 Consultations
79 Téléchargements
