A numerical study of vortex nucleation in 2D rotating Bose-Einstein condensates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
This article introduces a new numerical method for the minimization under constraints of a discrete energy modeling multicomponents rotating Bose-Einstein condensates in the regime of strong confinement and with rotation. Moreover, we consider both segregation and coexistence regimes between the components. The method includes a discretization of a continuous energy in space dimension 2 and a gradient algorithm with adaptive time step and projection for the minimization. It is well known that, depending on the regime, the minimizers may display different structures, sometimes with vorticity (from singly quantized vortices, to vortex sheets and giant holes). In order to study numerically the structures of the minimizers, we introduce in this paper a numerical algorithm for the computation of the indices of the vortices, as well as an algorithm for the computation of the indices of vortex sheets. Several computations are carried out, to illustrate the efficiency of the method, to cover different physical cases, to validate recent theoretical results as well as to support conjectures. Moreover, we compare this method with an alternative method from the literature.
main.pdf (7.04 Mo) Télécharger le fichier
hal-03818063 , version 1 (03-11-2022)
hal-03818063 , version 2 (11-04-2024)
Guillaume Dujardin, Ingrid Lacroix-Violet, Anthony Nahas. A numerical study of vortex nucleation in 2D rotating Bose-Einstein condensates. 2024. ⟨hal-03818063v2⟩
62 Consultations
56 Téléchargements
