Biokinetics and internal dosimetry of tritiated steel particles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Toxics Année : 2022
Decommissioning fission and fusion facilities can result in the production of airborne particles containing tritium that could inadvertently be inhaled by workers directly involved in the operations, and potentially others, resulting in internal exposures to tritium. Of particular interest in this context, given the potentially large masses of material involved, is tritiated steel. The International Commission on Radiological Protection (ICRP) has recommended committed effective dose coefficients for inhalation of some tritiated materials, but not specifically for tritiated steel. The lack of a dose coefficient for tritiated steel is a concern given the potential importance of the material. To address this knowledge gap, a “dissolution” study, in vivo biokinetic study in a rodent model (1 MBq intratracheal instillation, 3-month follow-up) and associated state-of-the-art modelling were undertaken to derive dose coefficients for model tritiated steel particles. A committed effective dose coefficient for the inhalation of 3.3 × 10$^{−12}$ Sv Bq$^{−1}$ was evaluated for the particles, reflecting an activity median aerodynamic diameter (AMAD) of 13.3 µm, with the value for a reference AMAD for workers (5 µm) of 5.6 × 10$^{−12}$ Sv Bq$^{−1}$ that may be applied to occupational inhalation exposure to tritiated steel particles.
Smith_2022_tritium_steel.PDF (12.92 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-03819106 , version 1 (01-02-2023)
Paternité
Rachel Smith, Michele Ellender, Chang Guo, Derek Hammond, Adam Laycock, et al.. Biokinetics and internal dosimetry of tritiated steel particles. Toxics, 2022, 10 (10), pp.602. ⟨10.3390/toxics10100602⟩. ⟨hal-03819106⟩
37 Consultations
16 Téléchargements
