Sparse Weighted K-Means for Groups of Mixed-Type Variables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2022
Assessing the underlying structure of a dataset is often done by training a clustering procedure on the features describing the data. In practice, while the data may be described by a large number of features, only a minority of them may be actually informative with regard to the structure. Furthermore, redundant features may also bias the clustering, whether one speaks of redundancy in the informative or the uninformative features. The present contribution aims at illustrating two sparse clustering methods designed for mixed data (made of numerical and categorical features). The proposed methods summarise redundant features into groups, and select the most relevant groups of features only in the clustering procedure. The performances and the interpretability of the sparse methods are illustrated on a real-life data set.
hal-03827823 , version 1 (24-10-2022)
Marie Chavent, Madalina Olteanu, Marie Cottrell, Jérôme Lacaille, Alex Mourer. Sparse Weighted K-Means for Groups of Mixed-Type Variables. Springer International Publishing, 533, 2022, Lecture Notes in Networks and Systems, ⟨10.1007/978-3-031-15444-7⟩. ⟨hal-03827823⟩
104 Consultations
0 Téléchargements
