CREMMA Medii Aevi: Literary manuscript text recognition in Latin - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This paper present a novel segmentation and handwritten text recognition dataset for Medieval Latin, from the 11 th to the 16 th century. It connects with Medieval French dataset as well as ealier Latin dataset, by enforcing common guidelines. We provide our own addition to Ariane Pinche's Old French guidelines to deal with specific Latin case. We also offer an overview of how we addressed this dataset compilation through the use of pre-existing resources. With a higher abbreviation ratio and a better representation of abbreviating marks, we offer new models that outperform the base Old French model on Latin dataset, reaching readability levels on unknown manuscripts.
documentation_CREMMA_Medieval_LAT-2.pdf (1.64 Mo) Télécharger le fichier
hal-03828353 , version 1 (25-10-2022)
hal-03828353 , version 2 (02-11-2022)
hal-03828353 , version 3 (29-11-2022)
hal-03828353 , version 4 (11-01-2023)
hal-03828353 , version 5 (16-04-2023)
  • HAL Id : hal-03828353 , version 2
Thibault Clérice, Malamatenia Vlachou-Efstathiou, Alix Chagué. CREMMA Medii Aevi: Literary manuscript text recognition in Latin. 2022. ⟨hal-03828353v2⟩
867 Consultations
476 Téléchargements
