Simultaneous off-the-grid learning of mixtures issued from a continuous dictionary
In this paper we observe a set, possibly a continuum, of signals corrupted by noise. Each signal is a finite mixture of an unknown number of features belonging to a continuous dictionary. The continuous dictionary is parametrized by a real non-linear parameter. We shall assume that the signals share an underlying structure by assuming that each signal has its active features included in a finite and sparse set.
We formulate regularized optimization problem to estimate simultaneously the linear coefficients in the mixtures and the non-linear parameters of the features. The optimization problem is composed of a data fidelity term and a $(\ell_1,L^p)$-penalty. We call its solution the Group-Nonlinear-Lasso and provide high probability bounds on the prediction error using certificate functions. Following recent works on the geometry of off-the-grid methods, we show that such functions can be constructed provided the parameters of the active features are pairwise separated by a constant with respect to a Riemannian metric.
When the number of signals is finite and the noise is assumed Gaussian, we give refinements of our results for $p=1$ and $p=2$ using tail bounds on suprema of Gaussian and $\chi^2$ random processes. When $p=2$, our prediction error reaches the rates obtained by the Group-Lasso estimator in the multi-task linear regression model. Furthermore, for $p=2$ these prediction rates are faster than for $p=1$ when all signals share most of the non-linear parameters.
bj_template_final.pdf (359 Ko)
Télécharger le fichier
supplementary_material_BEJ1724.pdf (237.1 Ko)
