Adaptive importance sampling based on fault tree analysis for piecewise deterministic Markov process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Piecewise deterministic Markov processes (PDMPs) can be used to model complex dynamical industrial systems. The counterpart of this modeling capability is their simulation cost, which makes reliability assessment untractable with standard Monte Carlo methods. A significant variance reduction can be obtained with an adaptive importance sampling (AIS) method based on a cross-entropy (CE) procedure. The success of this method relies on the selection of a good family of approximations of the committor function of the PDMP. In this paper original families are proposed. They are well adapted to high-dimensional industrial systems. Their forms are based on reliability concepts related to fault tree analysis: minimal path sets and minimal cut sets. The proposed method is discussed in detail and applied to academic systems and to a realistic system from the nuclear industry.
AIS_for_PDMP_by_FTA_v2-1.pdf (1 Mo) Télécharger le fichier
ttrjgcnyfqdfmdqdpfvxmzypsqdzxxhw.zip (357.16 Ko) Télécharger le fichier
hal-03831922 , version 1 (27-10-2022)
hal-03831922 , version 2 (14-06-2023)
  • HAL Id : hal-03831922 , version 2
Guillaume Chennetier, Hassane Chraibi, Anne Dutfoy, Josselin Garnier. Adaptive importance sampling based on fault tree analysis for piecewise deterministic Markov process. 2023. ⟨hal-03831922v2⟩
53 Consultations
31 Téléchargements
