Robustness of organ morphology is associated with modules of co-expressed genes related to plant cell wall - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
Annamaria Kiss
Reproducibility in organ size and shape is a fundamental trait of living organisms. The mechanisms underlying such robustness remain, however, to be elucidated. Taking the sepal of Arabidopsis as a model, we investigated whether variability of gene expression plays a role in variation of organ morphology. To address this question, we produced a dataset composed of both transcriptomic and morphological information obtained from 27 individual sepals from wild-type plants. Although nearly identical in their genetic background, environment, and developmental stage, these sepals exhibited appreciable variability in both morphology and transcriptome. We identified modules of co-expressed genes in sepals, three of which correlated significantly with morphology, revealing biologically relevant gene regulatory networks. Interestingly, cell-wall related genes were overrepresented in two of these three modules. Additionally, we found that highly variable genes were unexpectedly enriched in cell-wall related processes. We then analyzed sepal morphology from 16 cell-wall mutants and found that the more a gene is expressed in wild-type, the more variable the morphology of the corresponding mutant. Altogether, our work unravels the contribution of cell-wall related genes to the robustness of sepal morphology. More generally, we propose that canalizing traits during development could rely on the modulation of highly expressed genes.
Hartasanchez et al 2022.pdf (6.52 Mo) Télécharger le fichier
hal-03832424 , version 1 (27-10-2022)
Diego A Hartasánchez, Annamaria Kiss, Virginie Battu, Mathilde Dumond, Charline Soraru, et al.. Robustness of organ morphology is associated with modules of co-expressed genes related to plant cell wall. 2022. ⟨hal-03832424⟩
273 Consultations
45 Téléchargements
