Analytical Properties for a Stochastic Rotating Shallow Water Model Under Location Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Fluid Mechanics Année : 2023
The rotating shallow water model is a simplification of oceanic and atmospheric general circulation models that are used in many applications such as surge prediction, tsunami tracking and ocean modelling. In this paper we introduce a class of rotating shallow water models which are stochastically perturbed in order to incorporate model uncertainty into the underlying system. The stochasticity is chosen in a judicious way, by following the principles of location uncertainty, as introduced in Mémin (Geophys Astrophys Fluid Dyn 108(2):119–146, 2014). We prove that the resulting equation is part of a class of stochastic partial differential equations that have unique maximal strong solutions. The methodology is based on the construction of an approximating sequence of models taking value in an appropriately chosen finite-dimensional Littlewood-Paley space. Finally, we show that a distinguished element of this class of stochastic partial differential equations has a global weak solution.
LU-SRSW - Analytical_properties (6).pdf (526.73 Ko) Télécharger le fichier
hal-03832450 , version 1 (27-10-2022)
Oana Lang, Dan Crisan, Étienne Mémin. Analytical Properties for a Stochastic Rotating Shallow Water Model Under Location Uncertainty. Journal of Mathematical Fluid Mechanics, 2023, 25 (2), pp.29. ⟨10.1007/s00021-023-00769-9⟩. ⟨hal-03832450⟩
91 Consultations
58 Téléchargements
