Fluid-rigid body interaction using the finite element method and ale formulation : framework, implementation and benchmarking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
We consider the problem of moving rigid bodies in a Newtonian fluid. The fluid-solid problem is solved using the finite element method, and the solution is based on the Arbitrary-Lagrangian-Eulerian description of the fluid with conforming treatment of moving interfaces. Numerical experiments are discussed, and the results are validated with the literature. The results are obtained with the Feel++ open source library [17].
paper_rigid_bodies_benchmark_HAL.pdf (9.24 Mo) Télécharger le fichier
hal-03835136 , version 1 (31-10-2022)
  • HAL Id : hal-03835136 , version 1
Luca Berti, Vincent Chabannes, Laetitia Giraldi, Christophe Prud'Homme. Fluid-rigid body interaction using the finite element method and ale formulation : framework, implementation and benchmarking. 2022. ⟨hal-03835136⟩
76 Consultations
120 Téléchargements
