A positive perspective on term representation: Extended paper - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We use the focused proof system LJF as a framework for describing term structures and substitution. Since the proof theory of LJF does not pick a canonical polarization for primitive types, two different approaches to term representation arise. When primitive types are given the negative polarity, LJF proofs encode terms as tree-like structures in a familiar fashion. In this situation, cut elimination also yields the familiar notion of substitution. On the other hand, when primitive types are given the positive polarity, LJF proofs yield a structure in which explicit sharing of term structures is possible. Such a representation of terms provides an explicit method for sharing term structures. In this setting, cut elimination yields a different notion of substitution. We illustrate these two approaches to term representation by applying them to the encoding of untyped λ-terms. We also exploit concurrency theory techniques-namely traces and simulation-to compare untyped λ-terms using such different structuring disciplines.
root.pdf (404.06 Ko) Télécharger le fichier
hal-03843587 , version 1 (08-11-2022)
hal-03843587 , version 2 (10-11-2022)
  • HAL Id : hal-03843587 , version 1
Dale Miller, Jui-Hsuan Wu. A positive perspective on term representation: Extended paper. CSL 2023: Computer Science Logic, Feb 2023, Warsaw, Poland. ⟨hal-03843587v1⟩
118 Consultations
58 Téléchargements
