Using integer linear programming for correctly rounded multipartite architectures
This article introduces several improvements to the multipartite method, a generic technique for the hardware implementation of numerical functions. A multipartite architecture replaces a table of value with several tables and an adder tree. Here, the optimization of multipartite tables is formalized using Integer Linear Programming so that generic ILP solvers can be used. This improves the quality of faithfully rounded architectures compared to the state of the art. The proposed approach also enables correctly rounded multipartite architectures, providing errorless table compression. This improves the area by a factor 5 without any performance penalty compared with the state of the art in errorless compression. Another improvement of the proposed work is a cost function that attempts to predict the total cost of an architecture in FPGA architectural LUTs, where most of the previous works only count the size of the tables, thus ignoring the cost of the adder tree.
Arithmétique des ordinateurs
