Revisiting the role of friction coefficients in granular collapses: confrontation of 3D non-smooth simulations with experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fluid Mechanics Année : 2023
In this paper, transient granular flows are examined both numerically and experimentally. Simulations are performed using the continuous 3D granular model introduced in Daviet & Bertails-Descoubes (2016b), which represents the granular medium as an inelastic and dilatable continuum subject to the Drucker-Prager yield criterion in the dense regime. One notable feature of this numerical model is to resolve such a non-smooth rheology without any regularisation. We show that this non-smooth model, which relies on a constant friction coefficient, is able to reproduce with high fidelity various experimental granular collapses over inclined erodible beds, provided the friction coefficient is set to the avalanche angle - and not to the stop angle, as generally done. In order to better characterise the range of validity of the fully plastic rheology in the context of transient frictional flows, we further revisit scaling laws relating the shape of the final collapse deposit to the initial column aspect ratio, and accurately recover established power-law dependences up to aspect ratios in the order of 10. The influence of sidewall friction is then examined through experimental and simulated collapses with varying channel widths. The analysis offers a comprehensive framework for estimating the effective flow thickness in relation to the channel width, thereby challenging previously held assumptions regarding its estimation in the literature. Finally, we discuss the possibility to extend the constant coefficient model with a hysteretic model in order to refine the predictions of the early-stage dynamics of the collapse. This illustrates the potential effects of such phenomenology on transient flows, paving the way to more elaborate analysis.
article-JFM.pdf (4.09 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-03845323 , version 1 (09-11-2022)
hal-03845323 , version 2 (14-11-2022)
hal-03845323 , version 3 (03-10-2023)
hal-03845323 , version 4 (17-11-2023)
Paternité
  • HAL Id : hal-03845323 , version 3
Gauthier Rousseau, Thibaut Métivet, Hugo Rousseau, Gilles Daviet, Florence Bertails-Descoubes. Revisiting the role of friction coefficients in granular collapses: confrontation of 3D non-smooth simulations with experiments. Journal of Fluid Mechanics, inPress. ⟨hal-03845323v3⟩
310 Consultations
86 Téléchargements
