Simple derivation of moiré-scale continuous models for twisted bilayer graphene - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Physical Review B Year : 2023
We provide a formal derivation of a reduced model for twisted bilayer graphene (TBG) from Density Functional Theory. Our derivation is based on a variational approximation of the TBG Kohn-Sham Hamiltonian and asymptotic limit techniques. In contrast with other approaches, it does not require the introduction of an intermediate tight-binding model. The so-obtained model is similar to that of the Bistritzer-MacDonald (BM) model but contains additional terms. Its parameters can be easily computed from Kohn-Sham calculations on single-layer graphene and untwisted bilayer graphene with different stackings. It allows one in particular to estimate the parameters $w_{AA}$ and $w_{AB}$ of the BM model from first principles. The resulting numerical values, namely $w_{AA} = w_{AB} ≃ 126$ meV for the experimental interlayer mean distance are in good agreement with the empirical values $w_{AA} = w_{AB} = 110$ meV obtained by fitting to experimental data. We also show that if the BM parameters are set to $w_{AA} = w_{AB} ≃ 126$ meV, the BM model is an accurate approximation of our reduced model
Dates and versions
hal-03859731 , version 1 (18-11-2022)
Identifiers
Cite
Éric Cancès, Louis Garrigue, David Gontier. Simple derivation of moiré-scale continuous models for twisted bilayer graphene. Physical Review B, 2023, 107 (15), pp.155403. ⟨10.1103/PhysRevB.107.155403⟩. ⟨hal-03859731⟩
49 View
0 Download
Share
