Compression of a pressurized spherical shell by a spherical or flat probe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Etienne Couturier
Dominic Vella
  • Fonction : Auteur
Arezki Boudaoud
Measuring the mechanical properties of cells and tissues often involves indentation with, or compression between, two plates. Previously, different theoretical approaches have been developed to retrieve material parameters (e.g. elastic modulus) or state variables (e.g. pressure) from such experiments. Here, we extend previous theoretical work on indentation of a spherical pressurized shell by a point force to cover indentation by a spherical probe or a plate. We provide formulae that enable the modulus or pressure to be deduced from experimental results with realistic contact geometries, giving different results that are applicable depending on pressure level. We expect our results to be broadly useful when investigating biomechanics or mechanobiology of cells and tissues.
hal-03860474 , version 1 (22-11-2021)
hal-03860474 , version 2 (18-11-2022)
Etienne Couturier, Dominic Vella, Arezki Boudaoud. Compression of a pressurized spherical shell by a spherical or flat probe. 2021. ⟨hal-03860474v1⟩
52 Consultations
92 Téléchargements
