A Polyhedral Approach for Scalar Promotion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Memory accesses are a well known bottleneck whose impact might be mitigated by using properly the memory hierarchy until registers. In this paper, we address array scalarization, a technique to turn temporary arrays into a collection of scalar variables to be allocated to registers. We revisit array scalarization in the light of the recent advances of the polyhedral model, a general framework to design optimizing program transformations. We propose a general algorithm for array scalarization, ready to be plugged in a polyhedral compiler, among other passes. Our scalarization algorithm operates on the polyhedral intermediate representation. In particular, our scalarization algorithm is parametrized by the program schedule possibly computed by a previous compilation pass. We rely on schedule-directed array contraction and we propose a loop tiling algorithm able to reduce the footprint down to the available amount of registers on the target architecture. Experimental results confirm the efficiency of our approach.
compas22scalarization.pdf (800.79 Ko) Télécharger le fichier
hal-03862223 , version 1 (21-11-2022)
  • HAL Id : hal-03862223 , version 1
Alec Sadler, Christophe Alias, Hugo Thievenaz. A Polyhedral Approach for Scalar Promotion. Conférence francophone d'informatique en Parallélisme, Architecture et Système (COMPAS'22), Jul 2022, Amiens, France. ⟨hal-03862223⟩
40 Consultations
16 Téléchargements
