Mapping series-parallel streaming applications on hierarchical platforms with reliability and energy constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2022
Streaming applications come from various application fields such as physics, where data is continuously generated and must be processed on the fly. Typical streaming applications have a series-parallel dependence graph, and they are processed on a hierarchical failure-prone platform, as for instance in miniaturized satellites. The goal is to minimize the energy consumed when processing each data set, while ensuring real-time constraints in terms of processing time. Dynamic voltage and frequency scaling (DVFS) is used to reduce the energy consumption, and we ensure a reliable execution by either executing a task at maximum speed, or by triplicating it, so that the time to execute a data set without failure is bounded. We propose a structure rule to partition the series-parallel applications and map the application onto the platform, and we prove that the optimization problem is NP-complete. We design a dynamic-programming algorithm for the special case of linear chains, which is optimal for a special class of schedules. Furthermore, this algorithm provides an interesting heuristic and a building block for designing heuristics for the general case. The heuristics are compared to a baseline solution, where each task is executed at maximum speed. Simulations on realistic settings demonstrate the good performance of the proposed heuristics; in particular, significant energy savings can be obtained.
main_JPDC.pdf (448.82 Ko) Télécharger le fichier
hal-03863951 , version 1 (21-11-2022)
Changjiang Gou, Anne Benoit, Mingsong Chen, Loris Marchal, Tongquan Wei. Mapping series-parallel streaming applications on hierarchical platforms with reliability and energy constraints. Journal of Parallel and Distributed Computing, 2022, 163, pp.45-61. ⟨10.1016/j.jpdc.2022.01.016⟩. ⟨hal-03863951⟩
59 Consultations
96 Téléchargements
