Minimum-Cost Temporal Walks under Waiting-Time Constraints in Linear Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In a temporal graph, each edge is available at specific points in time. Such an availability point is often represented by a "temporal edge" that can be traversed from its tail only at a specific departure time, for arriving in its head after a specific travel time. In such a graph, the connectivity from one node to another is naturally captured by the existence of a temporal path where temporal edges can be traversed one after the other. When imposing constraints on how much time it is possible to wait at a node in-between two temporal edges, it then becomes interesting to consider temporal walks where it is allowed to visit several times the same node, possibly at different times. We study the complexity of computing minimum-cost temporal walks from a single source under waiting-time constraints in a temporal graph, and ask under which conditions this problem can be solved in linear time. Our main result is a linear time algorithm when temporal edges are provided in input by non-decreasing departure time and also by non-decreasing arrival time. We use an algebraic framework for manipulating abstract costs, enabling the optimization of a large variety of criteria or even combinations of these. It allows to improve previous results for several criteria such as number of edges or overall waiting time. This result is somehow optimal: a logarithmic factor in the time complexity appears to be necessary if the input contains only one ordering of the temporal edges (either by arrival times or departure times).
main-long.pdf (398.66 Ko) Télécharger le fichier
hal-03864725 , version 1 (21-11-2022)
hal-03864725 , version 2 (20-01-2023)
Filippo Brunelli, Laurent Viennot. Minimum-Cost Temporal Walks under Waiting-Time Constraints in Linear Time. 2022. ⟨hal-03864725v1⟩
57 Consultations
27 Téléchargements
