StarPU profiling interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
This document introduces the programming interface exposed by the StarPU task-based parallel runtime system for performance monitoring tools to collect performance-related metrics on the execution of StarPU applications. It defines the entry point, the callback methods, the performance counters available. It also presents the usage of the mechanisms.
StarPU_profiling_interface.pdf (179.84 Ko) Télécharger le fichier
hal-03868526 , version 1 (29-11-2022)
  • HAL Id : hal-03868526 , version 1
Olivier Aumage, Camille Coti. StarPU profiling interface. Inria & Labri, Université de Bordeaux; Université du Québec à Montréal. 2022. ⟨hal-03868526⟩
88 Consultations
51 Téléchargements
