The Weak (2,2)-Labelling Problem for graphs with forbidden induced structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Weak $(2,2)$-Conjecture is a graph labelling problem asking whether all connected graphs of at least three vertices can have their edges assigned red labels~$1$ and $2$ and blue labels~$1$ and~$2$ so that any two adjacent vertices are distinguished either by their sums of incident red labels, or by their sums of incident blue labels. This problem emerged in a recent work aiming at proposing a general framework encapsulating several distinguishing labelling problems and notions, such as the well-known 1-2-3 Conjecture and so-called locally irregular decompositions. In this work, we prove that the Weak $(2,2)$-Conjecture holds for two classes of graphs defined in terms of forbidden induced structures, namely claw-free graphs and graphs with no pair of independent edges. One main point of interest for focusing on such classes of graphs is that the 1-2-3 Conjecture is not known to hold for them. Also, these two classes of graphs have unbounded chromatic number, while the 1-2-3 Conjecture is mostly understood for classes with bounded and low chromatic number.
9508.pdf (532.54 Ko) Télécharger le fichier
hal-03869508 , version 1 (24-11-2022)
Julien Bensmail, Hervé Hocquard, Pierre-Marie Marcille. The Weak (2,2)-Labelling Problem for graphs with forbidden induced structures. CALDAM 2023 - 9th Annual International Conference on Algorithms and Discrete Applied Mathematics, Feb 2023, Gandhinagar, India. ⟨10.1007/978-3-031-25211-2_16⟩. ⟨hal-03869508⟩
33 Consultations
35 Téléchargements
