Learning Goal-Conditioned Policies Offline with Self-Supervised Reward Shaping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Developing agents that can execute multiple skills by learning from pre-collected datasets is an important problem in robotics, where online interaction with the environment is extremely time-consuming. Moreover, manually designing reward functions for every single desired skill is prohibitive. Prior works targeted these challenges by learning goal-conditioned policies from offline datasets without manually specified rewards, through hindsight relabeling. These methods suffer from the issue of sparsity of rewards, and fail at long-horizon tasks. In this work, we propose a novel self-supervised learning phase on the pre-collected dataset to understand the structure and the dynamics of the model, and shape a dense reward function for learning policies offline. We evaluate our method on three continuous control tasks, and show that our model significantly outperforms existing approaches, especially on tasks that involve long-term planning.
offline_reward_shaping_CoRL22.pdf (2.31 Mo) Télécharger le fichier
hal-03869706 , version 1 (24-11-2022)
  • HAL Id : hal-03869706 , version 1
Lina Mezghani, Sainbayar Sukhbaatar, Piotr Bojanowski, Alessandro Lazaric, Karteek Alahari. Learning Goal-Conditioned Policies Offline with Self-Supervised Reward Shaping. CoRL 2022- Conference on Robot Learning, Dec 2022, Auckland, New Zealand. pp.1-15. ⟨hal-03869706⟩
67 Consultations
135 Téléchargements
