Exploiting brain critical dynamics to inform Brain-Computer Interfaces performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sophie Dupont
  • Fonction : Auteur
  • PersonId : 889741
Danielle S Bassett
  • Fonction : Auteur
  • PersonId : 1079134
Viktor K Jirsa
The reconfiguration of large-scale interactions among multiple brain regions is characterized by aperiodic perturbations, called “Neuronal Avalanches”, which can be tracked non-invasively as they expand across the brain. As such, learning a new task might affect the path of propagation of neuronal avalanches. Brain-Computer Interfaces (BCIs) constitute a promising tool for establishing direct communication and control from the brain over external effectors but mastering them remains a poorly-understood learned skill. Therefore, neuronal avalanche measures may constitute natural candidates to inform the underlying brain processes and their reflection on brain signals. To test this hypothesis, we used source-reconstructed magneto/electroencephalography, comparing resting-state to motor imagery conditions during a BCI protocol. For each experimental condition, we computed an individual avalanche transition matrix, to track the probability that an avalanche would spread across any two regions. We found a robust topography of the edges that were affected by the execution of the task, which mainly hinge upon the premotor regions. Finally, we related the individual differences to the task performance, showing that significant correlations are predominantly positive and involve edges connecting pre/motor regions to parietal ones. Our findings suggest that avalanches capture functionally-relevant processes crucial for alternative BCI designing.
BrainCriticality_2022_Talk_CORSI_HAL_compressed.pdf (1.54 Mo) Télécharger le fichier
hal-03871532 , version 1 (06-12-2022)
  • HAL Id : hal-03871532 , version 1
Marie-Constance Corsi, Pierpaolo Sorrentino, Denis P Schwartz, Nathalie George, Laurent Hugueville, et al.. Exploiting brain critical dynamics to inform Brain-Computer Interfaces performance. Brain Criticality Hybrid Meeting 2022, Nov 2022, Bethesda, United States. ⟨hal-03871532⟩
52 Consultations
10 Téléchargements
