Analysis of sampling methods for imaging a periodic layer and its defects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
We revisit the differential sampling method introduced in [9] for the identification of a periodic domain and some local perturbation. We provide a theoretical justification of the method that avoids assuming that the local perturbation is also periodic. Our theoretical framework uses functional spaces with continuous dependence with respect to the Floquet-Bloch variable. The corner stone of the analysis is the justification of the Generalized Linear Sampling Method in this setting for a single Floquet-Bloch mode.
BHJ2022.pdf (364.65 Ko) Télécharger le fichier
hal-03876852 , version 1 (28-11-2022)
hal-03876852 , version 2 (03-02-2023)
hal-03876852 , version 3 (19-03-2023)
  • HAL Id : hal-03876852 , version 1
Yosra Boukari, Houssem Haddar, Nouha Jenhani. Analysis of sampling methods for imaging a periodic layer and its defects. 2022. ⟨hal-03876852v1⟩
109 Consultations
80 Téléchargements
