Inside-Outside Duality for Modified Transmission Eigenvalues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems and Imaging Année : 2022
We introduce a new modified spectrum associated with the scattering from penetrable objects using the modified background technique. We prove that the inside-outside duality method allows to reconstruct this spectrum from full aperture far field measurements at a fixed frequency. The method is numerically tested and validated on some synthetic examples.
HKM2022.pdf (503.87 Ko) Télécharger le fichier
hal-03876859 , version 1 (28-11-2022)
hal-03876859 , version 2 (16-01-2023)
Paternité
Houssem Haddar, Moez Khenissi, Marwa Mansouri. Inside-Outside Duality for Modified Transmission Eigenvalues. Inverse Problems and Imaging , 2022, 17 (4), pp.798-816. ⟨10.3934/ipi.2023004⟩. ⟨hal-03876859v2⟩
74 Consultations
87 Téléchargements
