Development and Validation of Deep Learning Transformer Models for Building a Comprehensive and Real-time Trauma Observatory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
BACKGROUND In order to study the feasibility of setting up a national trauma observatory in France, OBJECTIVE we compared the performance of several automatic language processing methods on a multi-class classification task of unstructured clinical notes. METHODS A total of 69,110 free-text clinical notes related to visits to the emergency departments of the University Hospital of Bordeaux, France, between 2012 and 2019 were manually annotated. Among those clinical notes 22,481 were traumas. We trained 4 transformer models (deep learning models that encompass attention mechanism) and compared them with the TF-IDF (Term- Frequency - Inverse Document Frequency) associated with SVM (Support Vector Machine) method. RESULTS The transformer models consistently performed better than TF-IDF/SVM. Among the transformers, the GPTanam model pre-trained with a French corpus with an additional auto-supervised learning step on 306,368 unlabeled clinical notes showed the best performance with a micro F1-score of 0.969. CONCLUSIONS The transformers proved efficient multi-class classification task on narrative and medical data. Further steps for improvement should focus on abbreviations expansion and multiple outputs multi-class classification.
preprint-40843-accepted.pdf (1.2 Mo) Télécharger le fichier
hal-03877193 , version 1 (02-12-2022)
Gabrielle Chenais, Cédric Gil-Jardiné, Hélène Touchais, Marta Avalos Fernandez, Benjamin Contrand, et al.. Development and Validation of Deep Learning Transformer Models for Building a Comprehensive and Real-time Trauma Observatory. 2022. ⟨hal-03877193⟩
Collections
INRIA INRIA2 U1219
84 Consultations
107 Téléchargements
