Algebraic wavenumber identification method in presence of uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an algebraic wavenumber identification method to identify wavenumbers under stochastic conditions. Stochastic condition results from the introduction of small perturbation which is referred to the uncertainty of measurements points’ coordinates caused by the operation faults or problems with experimental errors. The proposed method is compared with two popular alternatives, namely: inhomogeneous wave correlation method and inverse convolution method which are both capable of extracting the bending wavenumbers of a meta-structure. A good performance is observed for the identification of complex wavenumbers in presence of uncertainty. In addition, the proposed method needs to solve a linear problem, reducing the computational cost compared to the inhomogeneous wave correlation method.
Xuefeng_Li_ndecs22.pdf (746.33 Ko) Télécharger le fichier
hal-03878845 , version 1 (30-11-2022)
Xuefeng Li, Mohamed Ichchou, Christophe Droz, Abdelmalek Zine, Noureddine Bouhaddi. Algebraic wavenumber identification method in presence of uncertainty. NDECS 2022 - 2nd International Conference on Non-Destructive Evaluation of Composite Structures, Apr 2022, Tetouan, Morocco. pp.00005, ⟨10.1051/matecconf/202236000005⟩. ⟨hal-03878845⟩
36 Consultations
29 Téléchargements
