Discrete Gagliardo-Nirenberg inequality and application to the finite volume approximation of a convection-diffusion equation with a Joule effect term - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2023
A discrete order-two Gagliardo–Nirenberg inequality is established for piecewise constant functions defined on a two-dimensional structured mesh composed of rectangular cells. As in the continuous framework, this discrete Gagliardo–Nirenberg inequality allows to control in particular the $L^4$ norm of the discrete gradient of the numerical solution by the $L^2$ norm of its discrete Hessian times its $L^\infty$ norm. This result is crucial for the convergence analysis of a finite volume method for the approximation of a convection–diffusion equation involving a Joule effect term on a uniform mesh in each direction. The convergence proof relies on compactness arguments and on a priori estimates under a smallness assumption on the data, which is essential also in the continuous framework.
paper_CC_CC_EC_R2.pdf (484.7 Ko) Télécharger le fichier
hal-03881410 , version 1 (01-12-2022)
hal-03881410 , version 2 (21-12-2023)
Caterina Calgaro, Clément Cancès, Emmanuel Creusé. Discrete Gagliardo-Nirenberg inequality and application to the finite volume approximation of a convection-diffusion equation with a Joule effect term. IMA Journal of Numerical Analysis, inPress, ⟨10.1093/imanum/drad063⟩. ⟨hal-03881410v2⟩
115 Consultations
169 Téléchargements
