ConSLAM: Periodically Collected Real-World Construction Dataset for SLAM and Progress Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kacper Pluta
Lucio Alcalde
  • Fonction : Auteur
  • PersonId : 1198034
Stanley Chee
  • Fonction : Auteur
  • PersonId : 1198035
Antony Bromley
  • Fonction : Auteur
  • PersonId : 1198036
Pierre Alliez
Hand-held scanners are progressively adopted to workflows on con- struction sites. Yet, they suffer from accuracy problems, preventing them from deployment for demanding use cases. In this paper, we present a real-world dataset collected periodically on a construction site to measure the accuracy of SLAM algorithms that mobile scanners utilize. The dataset contains time-synchronised and spatially registered images and LiDAR scans, inertial data and professional ground-truth scans. To the best of our knowledge, this is the first publicly available dataset which reflects the periodic need of scanning construction sites with the aim of accurate progress monitoring using a hand-held scanner.
047.pdf (8.88 Mo) Télécharger le fichier
hal-03883866 , version 1 (04-12-2022)
Maciej Trzeciak, Kacper Pluta, Yasmin Fathy, Lucio Alcalde, Stanley Chee, et al.. ConSLAM: Periodically Collected Real-World Construction Dataset for SLAM and Progress Monitoring. ECCV 2022 - European Conference on Computer Vision Workshops, Oct 2022, Tel Aviv, Israel. pp.317-331, ⟨10.1007/978-3-031-25082-8_21⟩. ⟨hal-03883866⟩
70 Consultations
276 Téléchargements
