Multi-Objective Genetic Programming for Explainable Reinforcement Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alessandro Ferreira Leite
Marc Schoenauer
Deep reinforcement learning has met noticeable successes recently for a wide range of control problems. However, this is typically based on thousands of weights and non-linearities, making solutions complex, not easily reproducible, uninterpretable and heavy. The present paper presents genetic programming approaches for building symbolic controllers. Results are competitive, in particular in the case of delayed rewards, and the solutions are lighter by orders of magnitude and much more understandable.
_EuroGP__Multi_Objective_Genetic_Programming_for_Explainable_Reinforcement_Learning.pdf (737.31 Ko) Télécharger le fichier
hal-03886307 , version 1 (06-12-2022)
Paternité
Mathurin Videau, Alessandro Ferreira Leite, Olivier Teytaud, Marc Schoenauer. Multi-Objective Genetic Programming for Explainable Reinforcement Learning. EUROGP 2022 - 25th European Conference on Genetic Programming, Apr 2022, Madrid, Spain. pp.278-293, ⟨10.1007/978-3-031-02056-8_18⟩. ⟨hal-03886307⟩
104 Consultations
267 Téléchargements
