The effects of role transitions and adaptation in human-cobot collaboration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Working Paper) Année : 2022
Collaborative robots (cobots) have the potential to augment productivity and the quality of life of human operators in the context of Industry 4.0 by providing them with physical assistance. For this reason, it is necessary to define the relationship between humans and cobots and to study how the two agents adapt to each other. However, to the best of our knowledge, literature is still missing insight into how humans perceive and react to changes in the cobot behavior. Specifically, a study of how humans adapt to changing roles and control strategies of collaborating robot is missing. To fill this gap, we propose a human study in which 16 participants executed a collaborative human-robot sawing task where the cobot altered between three different control strategies. We examined human adaptation when cobot suddenly changed the control strategy from one to another, resulting in six experimental conditions. The experiments were performed on a setup involving Kuka LBR iiwa robotic arm. The results suggest that transition influences movement performance in the early stages and at steady state, subjects prefer to abandon modes that require more effort and they adapt faster to energy demanding modes. Finally, for the specific task we studied, usually, subjects prefer collaborative mode with respect to fixed role ones.
main.pdf (1.82 Mo) Télécharger le fichier
hal-03890322 , version 1 (15-12-2022)
  • HAL Id : hal-03890322 , version 1
Lorenzo Vianello, Serena Ivaldi, Alexis Aubry, Luka Peternel. The effects of role transitions and adaptation in human-cobot collaboration. 2022. ⟨hal-03890322⟩
56 Consultations
131 Téléchargements
