APHYN-EP: Physics-based deep learning framework to learn and forecast cardiac electrophysiology dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Biophysically detailed mathematical modeling of cardiac electrophysiology is often computationally demanding, for example, when solving problems for various patient pathological conditions. Furthermore, it is still difficult to reduce the discrepancy between the output of idealized mathematical models and clinical measurements, which are usually noisy. In this paper, we propose a fast physics-based deep learning framework to learn cardiac electrophysiology dynamics from data. This novel framework has two components, decomposing the dynamics into a physical term and a data-driven term, respectively. This construction allows the framework to learn from data of different complexity. Using 0D in silico data, we demonstrate that this framework can reproduce the complex dynamics of transmembrane potential even in presence of noise in the data. Additionally, using ex vivo 0D optical mapping data of action potential, we show the ability of our framework to identify the relevant physical parameters for different heart regions.
STACOM2022_Workshop-ready.pdf (655.43 Ko) Télécharger le fichier
hal-03894974 , version 1 (12-12-2022)
  • HAL Id : hal-03894974 , version 1
Victoriya Kashtanova, Mihaela Pop, Ibrahim Ayed, Patrick Gallinari, Maxime Sermesant. APHYN-EP: Physics-based deep learning framework to learn and forecast cardiac electrophysiology dynamics. STACOM 2022 - 13th Workhop on Statistical Atlases and Computational Modelling of the Heart, Sep 2022, Singapore, Singapore. ⟨hal-03894974⟩
92 Consultations
159 Téléchargements
