Denoising of fMRI volumes using local low rank methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Functional Magnetic Resonance Imaging (fMRI) data provides deep insight on brain activity, but high-resolution (e.g. 1 mm isotropic) fMRI suffers from low signal-to-noise ratio (SNR). Recently several denoising methods have been proposed to boost the SNR of high-resolution fMRI images. In this work we carry out a prospective benchmark of local low-rank denoising methods by quantifying their performances on a retinotopy experimental paradigm that was submitted to six healthy volunteers during a 7 Tesla, 1 mm isotropic fMRI acquisition protocol. Out of the five tested approaches (NORDIC, MP-PCA, Hybrid-PCA, Optimal Threshold (OT) and Hybrid-OT), the OT approach outperforms its competitors in terms of statistical sensitivity and specificity both at the subject-and group-level. Additionally, by testing these denoising methods in different configurations of preprocessing pipelines, we demonstrate first that on average it is beneficial to denoise fMRI images prior to performing realignment (i.e. motion correction), and second that the OT approach performs better when applied to complex-valued fMRI images instead of magnitude-only ones. We also provide an open source implementation to promote a broader use of denoising methods in fMRI and enable reliable statistical data analysis at high spatial resolution.
isbi2023_denoise.pdf (1.34 Mo) Télécharger le fichier
hal-03895194 , version 1 (14-12-2022)
hal-03895194 , version 2 (10-03-2023)
  • HAL Id : hal-03895194 , version 1
Pierre-Antoine Comby, Zaineb Amor, Alexandre Vignaud, Philippe Ciuciu. Denoising of fMRI volumes using local low rank methods. ISBI 2023 - International Symposium on Biomedical Imaging, Apr 2023, Carthagena de India, Colombia. ⟨hal-03895194v1⟩
183 Consultations
266 Téléchargements
