Experimental analysis on dissimilarity metrics and sudden concept drift detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Learning from non-stationary data presents several new challenges. Among them, a significant problem comes from the sudden changes in the incoming data distributions, the so-called concept drift. Several concept drift detection methods exist, generally based on distances between distributions, either arbitrarily selected or context-dependent. This paper presents a straightforward approach for detecting concept drift based on a weighted dissimilarity metric over posterior probabilities. We also evaluate the performance of three well-known dissimilarity metrics when used by the proposed approach. Experimental evaluation has been done over ten datasets with injected sudden drifts in a binary classification context. Our results first suggest choosing the Kullback-Leibler divergence, and second, they show that our drift detection procedure based on dissimilarity measures is pretty efficient.
ISDA22hal.pdf (748.34 Ko) Télécharger le fichier
hal-03898901 , version 1 (14-12-2022)
  • HAL Id : hal-03898901 , version 1
Gerardo Rubino, Sebastián Basterrech, Jan Platoš, Michał Woźniak. Experimental analysis on dissimilarity metrics and sudden concept drift detection. ISDA 2022 - 22nd International Conference on Intelligent Systems Design and Applications, Dec 2022, virtual, United States. pp.1-8. ⟨hal-03898901⟩
35 Consultations
88 Téléchargements
