Acala: Aggregate Monitoring for Geo-Distributed Cluster Federations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distributed monitoring is an essential functionality to allow large cluster federations to efficiently schedule applications on a set of available geo-distributed resources. However, periodically reporting the precise status of each available server is both unnecessary to allow accurate scheduling and unscalable when the number of servers grows. This paper proposes Acala, a monitoring framework for geo-distributed cluster federations which aims to provide the management cluster with aggregate information about the entire cluster instead of individual servers. Our evaluations, based on actual deployment under controlled environment in the geodistributed Grid'5000 testbed, show that Acala reduces the crosscluster network traffic by up to 99% and the scrape duration by up to 55%.
main.pdf (707.34 Ko) Télécharger le fichier
hal-03899133 , version 1 (14-12-2022)
  • HAL Id : hal-03899133 , version 1
Chih-Kai Huang, Guillaume Pierre. Acala: Aggregate Monitoring for Geo-Distributed Cluster Federations. SAC 2023 - 38th ACM/SIGAPP Symposium On Applied Computing, Mar 2023, Tallinn, Estonia. pp.1-9. ⟨hal-03899133⟩
128 Consultations
75 Téléchargements
