ICLR 2022 Challenge for Computational Geometry & Topology: Design and Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of Machine Learning Research Année : 2022
Johan Mathe
  • Fonction : Auteur
This paper presents the computational challenge on differential geometry and topology that was hosted within the ICLR 2022 workshop “Geometric and Topo- logical Representation Learning”. The competition asked participants to provide implementations of machine learning algorithms on manifolds that would respect the API of the open-source software Geomstats (manifold part) and Scikit-Learn (machine learning part) or PyTorch. The challenge attracted seven teams in its two month duration. This paper describes the design of the challenge and summarizes its main findings.
myers22a (1).pdf (128.27 Ko) Télécharger le fichier
hal-03903044 , version 1 (16-12-2022)
Adele Myers, Saiteja Utpala, Shubham Talbar, Sophia Sanborn, Christian Shewmake, et al.. ICLR 2022 Challenge for Computational Geometry & Topology: Design and Results. Proceedings of Machine Learning Research, 2022, Topological, Algebraic and Geometric Learning Workshops 2022, 196, pp.269-276. ⟨10.5281/zenodo.6554616⟩. ⟨hal-03903044⟩
75 Consultations
91 Téléchargements
