On observer design for a class of time-varying Persidskii systems based on the invariant manifold approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we consider the state estimation problem for a class of non-autonomous Persidskii systems. This paper presents conditions on the existence and stability of a nonlinear observer based on the invariant manifold approach. The conditions are formulated using Linear Matrix Equalities (LME) and Inequalities (LMI). Two interesting applications of the result are presented: a reduced-order observer (e.g., an observer for unmeasured states) and regression, both in linear and nonlinear settings. An example to demonstrate the efficiency of results is provided.
Conference_version_reduced.pdf (455.63 Ko) Télécharger le fichier
hal-03903318 , version 1 (16-12-2022)
Paternité
  • HAL Id : hal-03903318 , version 1
Anatolii Khalin, Denis Efimov, Rosane Ushirobira. On observer design for a class of time-varying Persidskii systems based on the invariant manifold approach. European Control Conference (ECC), Jun 2022, London, France. ⟨hal-03903318⟩
20 Consultations
31 Téléchargements
